Car Alarm
Old 12-07-2006, 07:34 PM
IronFox's Avatar
Location: Burlington Iowa, where theres just as many tractors on the road as cars.
I noticed that i have a fuse in the car alarm part of the fuse box. How do i know if i have one? I work at a tire and lube shop and did an oil change on a 01 elantra and it had the alarm key fob and i didnt get one with my car.
Old 12-07-2006, 07:38 PM
You should do. They come with them from the factory, over here anyway.
Old 12-07-2006, 08:26 PM
prolly for the keyless entry if you have one. check my many many mods thread and you will see i ripped out 2 black boxes. one was for my keyless entry, the other one was for a shitty alarm that wasnt hooked up correctly.
Old 12-07-2006, 08:47 PM
no tiburon comes from the factory with an alarm. it's a dealer add on. you'll need to check under the dash on the fuse box side. check for any boxes that look stuffed or zip-tied in there.
Old 12-07-2006, 08:52 PM
Sousake Sagara's Avatar
Vehicle: 1997 RD Tiburon
^^ As he said.
Mine was not optioned keyless entry or alarm, I had an aftermarket alarm and keyless entry installed.
Old 12-07-2006, 10:45 PM
^ Odd. Whenever you look at specs for the Coupe, they always say that central locking & alarm come standard.
Actually, come to think of it, that may just be for the FX. Is yours an SX, maybe?
Old 12-07-2006, 10:56 PM
Mines an FX, Central locking (keylock enabled) but no alarm
I think you might be getting mixed up with the dealer fully optioned S-FX.
Old 12-07-2006, 11:37 PM
I was going off this...
But then again, mine is an FX & doesn't have cruise control so it's obviously not that accurate.
Old 12-08-2006, 08:18 AM
IronFox's Avatar
^^^^ mines got all the stuff for the fx model except for the power antenna. Is there a way of finding out without ripping apart the dash (its cold in iowa)? Maybe i could find the speaker for the alarm somewhere? And if i did find an alarm there, how could i go about getting the key fob for it?
Old 12-08-2006, 08:34 AM
they usually use the horn from the dealership.
Look under the dash mang! you don't need to tear anything apart. lay on your seat upside down.
