Car Is Acting Funny
Old 05-29-2007, 08:23 AM
streettibb28's Avatar
Vehicle: 1998/Hyundai/Tiburon
i drive a 1998 hyundai tiburon... i replaced the spark plugs and wires with ngk's at 60,000 thousand. 5 months ago the car was in an accident hit and run, when someone hit me in the font....i had it fixed at a shop...i have been driving it around to school up till now and i been trying to figure out why my steering wheel shakes at idle, i have 83,000 now and it feels slower and has less power then before.. i do have a cell on.. i think its the o2 sensors which im replacing this weekend when i get $$....i have no idea what it can be any help will be great.
thank you
Old 05-29-2007, 08:41 AM
landshark16's Avatar
Go to Autozone and get the code read first. Then come back and post up what the number of the code. That would be the most helpful.
Old 05-29-2007, 09:40 AM
<div class='quotetop'>QUOTE (landshark16 @ May 29 2007, 10:41 AM) <{POST_SNAPBACK}></div><div class='quotemain'>Go to Autozone and get the code read first. Then come back and post up what the number of the code. That would be the most helpful.</div>
ok...leaving to do that. i will post when i get back
ok the code is p1228...?
Old 05-29-2007, 09:57 AM
The ECM will set a code and the Malfunction Indicator Lamp (MIL) will turn on if the long-term fuel trim value goes 10% to 15% rich [for P1127] or lean [for P1128] for 30 seconds during two driving cycles when the following conditions are met:
  1. [*]
You should have other codes set.
Old 05-29-2007, 10:00 AM
jalmir's Avatar
Vehicle: Hyundai Elantra 2000
you sure it's 1228 and not 1128 ????
because 1228 is a manufacturer code and Hyundai doesn't use that code ...
Old 05-29-2007, 01:27 PM
type2ac's Avatar
Its definitally the o2 sensor. My car was doing the same thing and it was eating gas like a hummer cause the bad o2 sensor made it run extremely rich.
Old 05-29-2007, 06:11 PM
yea thats what i think too.. i am going to replace them this weekend smile.gif ...thanks for the help everyone..
Old 06-07-2007, 01:22 PM
ok so when i went back to autozone i had the man working there checks my codes for the check engine light and it was a P1128 not a P1228 the guy wrote it down wrong which pissed me off so now i dont know it means. when i give the car gas when im driving it bogs down and at idle it idles at 2000 rpm... 02.gif
Old 06-07-2007, 01:35 PM
Dweet's Avatar
DTM post above says p1128 is lean.. so if your ECU thinks the car is leanthen i can see it running rich to compensate for running lean... change the O2 sensor still.
Old 06-07-2007, 03:01 PM
thanks mang..... will do
