CAI filters
Re: The Person Above You
thanks guys, my car goes in to shop next week for gauge work, ill tell him 2 wash it lol, so your sure piping is 3 inches, cuz i mite get a new one for summer....
Just pick one up from the auto parts store. For the most part they're universal. Ive had a lot of different brand filters on my CAI. But most stores will let you return it if it doesnt fit.
Re: Kspec Maintec Header/Turbo Manifold GB *FULL!!!*
Did you ever take Geometry? Measure the circumference of the pipe (wrap the tape around the pipe or if you cant do that, take a string and wrap it around the pipe and mark it. Then measure the string). Divide that by 3.14. You now know the diameter of the pipe wink.gif
Re: NEW previously unreleased photo of Redz
np mang, now you can go back to your teacher and tell him/her that you actually USED something usefull LOL smile.gif
Re: Thin Subwoofers???
if your willing to spend the money, buy an apex-i filter. its a dry type cone filter, meaning theres no oil involved to help catch debris so it will breath better and they last a LONG time to. all you do is bang out the debris rinse it clean and slap it on again.
Re: brake lights are on, but shouldnt be
<div class='quotetop'>QUOTE (Casper)</div><div class='quotemain'>Did you ever take Geometry? Measure the circumference of the pipe (wrap the tape around the pipe or if you cant do that, take a string and wrap it around the pipe and mark it. Then measure the string). Divide that by 3.14. You now know the diameter of the pipe wink.gif</div>
huh?
if your trying to figure out the diameter, why would you do it the hard way?
You simply measure the diameter (top to bottom), best way is to use a calliper.
Done.
Anyway, Since we are talking math,... How about some trigonometry i use at work, hehhe tongue.gif
Such as,... How to surface grind an angle to an accurate height.
45 degrees divided by 2 = 22.5
22.5(tan)= 0.4142"
[.500" dowel diameter] divided by 2 = .250"
0.250" divided by Tan (0.4142") = 0.6035"
.250" + 0.6035" + [Height of desired intersect point] = your answer
Example:
0.250" + 0.6035" + 1.5 = 2.3535
Measure total height from the top of the 1/2" dowel with an indicator or height gauge.
0.7071 X [how much your over the intersect finish height]
example:
0.7071 X 0.021" = 0.0148"
simply place on Sine bar (5.000" in lengh) and do the math:
45 (Sine) = 0.7071 X 5. = 3.5355 [this is your gauge block height]
you must then grind (or machine/mill) 0.0148" to reach the desired height of the angle.
Easy as pie!! LOL
this is'nt even that hard,compared to some other things I must make in a days work as a Tool & Die maker wink.gif
huh?
Done.
22.5(tan)= 0.4142"
Example:
example:
Easy as pie!! LOL
