Buying New Muffler...
Vehicle: 2001 Hyundai Veilside Turbulence
Ok, so my tib is LOUD...like multiple tickets for being too loud LOUD.
I have headers, 2.5" Piping, No Cat [i know that will reduce noise when i get one on.] and a "tuner" muffler [aka grapefruit launcher]. I was wondering if anyone knew of a muffler that wasnt as openly loud as a tuner muffler...like a normal muffler so my car wont be so noisy but still have good performance. Also if anyone has a good street legal hi-flow cat manufacturer...that'd be great too. smile.gif
get a catco cat.. i would just get a cheap ebay muffler (grapefruit launcher) and leave the silencer in it..
do the cat FOR SURE, and get a silencer and that should be enough
that cat will help ALOT. i remember mine with the 'race cat' omfg.. can you say weedwacker..
have a cheap glasspack welded in there, that will help reduce alot of the noise, if the cat doesn't help enough.
Why bother getting a new muffler? Put a high flow cat on and see how it sounds. That'll help the environment too.
Then if it's still too loud (that usually does the job), then put a small resonator on.
Catco is good, so are the Magnaflow High Flows on ebay. You can get one for about 50 to 60 bucks.
get a small 15' thrush glasspack from amazon/summitracing, catco high flow. i have a magnaflow and it sounds basic, though not deep at all. i can't complain, sound is just where i want it butdo something tht hasn't been done before. research research research and i garuntee you won't be let down.
Remove the cat and you ARE putting yourself at risk, not to mention the environment and others. Get a Catco cat. You'll have better sound, smoother power and a clean conscience.
