Both Turn Signals Come On
Lol...this is so stupid...
But if I turn my left turn signal on, they both come on, same with the right.
Not sure why, and i'm not really sure what to check. Only thing's that I can think of that i've done is replaced a blown fuse, put in clear corners and replacement tail lights, and took apart my interior.
Everything else works fine though. And they come on in front/and back, kind like hazard/4-ways.
Did you replace the bulbs? Our turn signal bulbs have dual filaments... 1157 I believe. If you put in 1156, they fit, but only have one filament inside and won't blink but rather stay solid (arrows on dash will flash, but bulbs won't).
Look at the bulb, the base of it that screws into the connector, and see if it has 1 or 2 bumps on it. You want 2
If it's a clear bulb and you can see the filaments inside of it, see if it has 2.
lol, yup that's it. I had the exact same problem when I'd swapped some blue bulbs into my turn signals after getting clear corners. I was baffled too, so don't feel bad lol.
Haha ok that seems a bid odd, but ill check when I get home.
I got the kspec clear corners, pretty sure they had bulbs in them. I used those or the old ones. But will edit once I get home and check em out. Thanks smile.gif
Ok well apparently I can't edit.....=/
I put the old bulbs in, and the turn signals work, except for the left turn signal blinks like twice as fast as the right one lol. Not quite sure what's up with that lmao.gif
Vehicle: 97 Tiburon
<div class='quotetop'>QUOTE (mb499 @ Apr 3 2006, 08:03 PM) <{POST_SNAPBACK}></div><div class='quotemain'>the left turn signal blinks like twice as fast as the right one</div>
thats your hyper blinker fluid. it may be low
