Big Problem
Old 04-20-2005, 09:26 PM
Please don't quote the person above you.
Old 04-20-2005, 09:28 PM
OdessitPashka's Avatar
Check your MAF, plug all the sensors in, check your filter.
Regarding headers and CEL, I've had mine for over 2000mi with a test pipe and no CEL.
Old 04-21-2005, 05:34 AM
hamhead's Avatar
It could either be a fueling problem like everyone mentioned, or it could be an air leak. Are you sure there aren't any open spots along the intake? Even a pin-sized hole can create problems.
Air leaks usually cause lots of problems at idle and slow speeds, when you get up to speed and the carm gets warmed up, the problem lessens.
Old 04-21-2005, 08:44 AM
zoned019's Avatar
Vehicle: 97 Tib
are you sure that all of the clamps and stuff on your intake are secure and tight? all hoses are hooked up etc.
if you could find someone with an obd2 reader and hook it up to your car it and give us the trouble codes it would help a LOT im sure. hey, at least you can START your car. tongue.gif :angry:
Old 04-21-2005, 07:25 PM
switched everything back to stock to take it to the dealer tomorrow. with the stock stuff back in the problem is still there so its not with any of that. Ill post tomorrow when I find out what it was
Old 04-21-2005, 07:40 PM
gmantibby's Avatar
Could be you TPS also like someone already said check vac. lines on CAI and check direction of MAF. I had a similar problem but mine included the motor reving to 3gs on its own. Good lucl!
Old 04-23-2005, 08:32 AM
Got it fixed yesterday. The first O2 sensor was bad. So they replaced it for me and did a full check on the whole car. Now i just gotta get all my stuff back on.
Old 04-23-2005, 08:57 AM
cool.. glad to hear they fixed it and it was easy.
