Best procedure to get your tib up on 4 jack stands?
Vehicle: 2001 tib
Anyone care to explain the easiest way to get your car up on 4 jack stands?
I will be painting my calipers soon, changing all 4 brakes & rotors, installing SS lines, and want to remove all 4 wheels at the same time to do this.
Use the front jack point, put two jackstands under the car. Use the rear jackpoint, put two more jackstands under the car. There have been several threads recently on how to jack up a Tiburon.
If you do each side instead of front/rear there is a lot of shifting on the jack stands. That means it's less safe and more likely to shift and remove paint from something.
