Belt Comming Off Pulley Problem?
Vehicle: 1998 Hyundai Coupe
Hello All,
I have developed a belt comming off the water pulley problem all of a sudden?
The belt comes off the water pump pulley towards the powersteering belt.
I did have obx water pulley but I have replaced that with the OEM pulley but I still got the problem, I don't know what it is?
Is it possible that I have overtightened the pulley and maybe bent the water pump shaft or alternator shaft?
I am supercharged too, but I did not have this problem until last week when I tried to reduce belt slip by tightening the belt some more?
Does anyone know how tight a belt should be?
<div class='quotetop'>QUOTE (only1db @ Nov 24 2008, 09:18 AM) <{POST_SNAPBACK}></div><div class='quotemain'>you should have about 5mm of deflection...so when you press down on the belt it should move 5mms
DO NOT overtighten belt you will eventurally kill the water pump bearing/alt bearings</div>
What pressure is that at?
