Battery Wiring?
Ok so I started doing (what I thought would be.) a minor electric system replacement I.E. battery, alt, Fuel pump, (yeah I know FP ain't elec.)plugs/wire's. Tune up crap well low and behold wouldn't ya know it by BAT Connectors were crap so i decided to relace those as well I think i have it rewired correctly but I guess not because now it's acting crazy. When I turn the key to ACC everything turns on without a hitch. but when I turn it to the ON position Everything turns off but then for some reason it SLOWLY pulses back to normal ALMOST wont turn over nothing. does anyone have either a pic or a STUPID persons diagram I try'd seeing WTF was there but I can't read it
thanks for any help guys
![](https://www.hyundaiaftermarket.org/forum/images/ranks/forummod.png)
it sounds like you connected a positive terminal to a negative terminal on the battery. You should try to inspect it carefully and see if anything looks wrong. Take a picture and post it if you must. it's really hard to trace those wires back to the source.
