Battery Relocation Electronic Help
Vehicle: FX Coupe
I have relocated my battery to the trunk.
Im not to hot on electronics and stuff but i am wanting to fuse or circit break the wire near the battery before it runs through the car.
the wire will run to a distribution block in the engine bay where it will split to the starter motor and the fuse box + have one input spare
what size fuse should i use near the battery? or is there a better way to do this?
should i use a fused distribution block in the engine bay? again what size fuses????
Help
Thanks
Help
Thanks
Vehicle: 1998 Hyundai Tiburon FX
I used a 120amp circuit breaker in the trunk and a solid distribution block under the hood. If you want to use a fused block under the hood I would go with something that has at least 100amp fuses, since everything will be run from that block.
Vehicle: FX Coupe
Thanks Guys
much appreciated
how do you work out what size fuse to use? (for future reference)
hey redz brought a house and have been working on it/+ the coupe of course wink1.gif
much appreciated
