Ball Joint
Vehicle: 2000 Yellow Tib
Ball Joint
OK, so I've been working on replacing the driver side wheel front bearing on my tib. The steering knuckle is out, and I just had a machine shop press out and press in the new bearing. Woo!
However, the ball joint boot, which was already torn to begin with, got even more torn while separating it from the steering knuckle. Now I'm thinking I should just replace it while everything is apart. Can I just take the arm out, and grind the rivet down until it pops out, or do I have to bring it back to the machine shop? How much of a procedure is this?
