Autorx
i have searched autorx and found a few things but i want to know if it is worth it or not. i am trying everything to improve my gas mileage. i have heard this will remove the crap that builds up in the engine. i am also wondering the order i should do things in
the things i still want to do
1 seafoam through the vacuum lines
2 change my PCV valve
3 change oil
4 possible use autorx
5 clean my MAF and IAT sensors
any suggestions?
3 change oil
any suggestions?
I used it and got a great result. It was the first of a series that I did (pretty much what you have mentioned) so it did the most good (around 2-3mpg increase). The first cleaner you do to your engine is usually the best, each successive one gets progressively less result, but they're still worth doing.
I'd highly recommend it.
At first I thought you said you were considering doing an AutoX race to improve your gas mileage, I was like WTF M8?? lmao.gif
