Anyone Using Larger Than Stock Throttle Body?
Hey all is anyone here using a larger than stock throttle body? If we don't have a stock replacement option, I think I may look into having mine bored to a larger size. I once had Gude Performance bore the stock throtle body on my Toyota Celica and install a new bullfrog throttle plate. Would anyone else be interested?
im using a bored 58mm stocker from AltierHP and i like it alot. it costs 120+core and it does seem to have slightly better response. more then anything the engine just takes deeper breaths. idk if it make HP but it does allow the engine to do its job a little easier.
maybe someone with an actuall BBTB could chime in with more
<div class='quotetop'>QUOTE (mosul210 @ Dec 15 2008, 07:00 AM) <{POST_SNAPBACK}></div><div class='quotemain'>Hey all is anyone here using a larger than stock throttle body? If we don't have a stock replacement option, I think I may look into having mine bored to a larger size. I once had Gude Performance bore the stock throtle body on my Toyota Celica and install a new bullfrog throttle plate. Would anyone else be interested?</div>
Are you kidding me? Mosul, I know you are new, but SEARCH. There are a few hundred threads on BBTB's.
Closed.
Closed.
