Anyone Got Connections For A Cnc Job?
Don't know if this is the right place for me to say this, but oh well.
I would be interested in this secondary pulley for cruise, since I don't have it for the 65mm TB. But, wouldn't we need a longer mounting shaft to bolt the pulley to and hold the throttle plate?
I was going to cut the longer shaft from the stock TB and weld an extension onto the 65mm shaft, then use the stock secondary pulley for cruise.
What exactly are you getting done redz, if you don't mind me asking.
Thanks.
Thanks.
I'll let you all know when this is ready. You won't need an extension, thank god. These work fine. Trust me, you don't want to have to pull that stuff off.
We MAY try to do a stud extender so that the pulley is lined up with the cable correctly. This will prevent possible cable wear like I had with my dual pulley on my RSide BBTB.
What we are getting done is the pulley. With the hole aligned better with the stock throttle pulley and the correct size hole in it for the lug. If OZ thinks he can do it also, we will do a stud extender, I've got a few ideas on how to do it, but it WILL work without it.
Busy weekend around the house. No worries, I'll probably do it tomorrow.
Yup. Sorry, I finally got my new pulleys installed yesterday, I'll sit down today and measure this all out.
Do you have cruise?
Do you have cruise?
