Annoying Squeal
#21
Thanks man, i'll try that. btw, your sig says youre lookin to do the ecu swap, he has one he just put up for sake >> http://www.rdtiburon.com/index.php?showtop...mp;#entry383321
#22
![](https://www.hyundaiaftermarket.org/forum/images/ranks/forummod.png)
Just to add a bit to this, winter time tends to dry out belts more then the summer time. You can make a belt last alot longer by spraying belt dressing on the belts while they are moving. It's a rejuvinator for the belts. It will get into the rubber, moisturize it, and stop them from squealing. If you want to do a repair, it's best to replace the belts. For a quick fix, tightening and belt dressing is the way to go and you'll get a couple more months out of them.
#23
YAY, replaced my power steering and alternator belts last night and no more squeal I looked at the old belt this morning after some sleep and yeah, its superglazed
#24
The tibby I just purchased has this same problem, the belts squeal when the engine is cold. Since I don't know when the belts were last replaced I will replace them all to be on the safe side. Good thread, very helpful.
#25
![](https://www.hyundaiaftermarket.org/forum/images/ranks/admin.png)
Belt squeel is usually caused by them being too loose. I'm glad the problem was fixed, but I would've spent time looking at the tightness. I would also blame the belt before any other component (P/S, alt, etc.) and make sure it is NOT the belts before replacing any other part.
Glad you fixed the problem.
