Alternator Help!
Old 02-18-2010, 03:10 PM
Ok i made this video to illustrate and so people can hear what im talking about
as you can hear in video, i am getting this lound pitch noise with a load on the car (headlights cuz of HIDS, AC and even when i turn the wheel), I recently changed out my Alternator belt as well as Power Steering and including the OBX Power steering pulley i had on there, now its back to stock and yet i am getting this noise.
Could it be the pulley on the alternator, or the alernator it self and time to rebuild it?
Im at a complete losted with this and its making it annoying to drive...
alright guys help me out
Old 02-18-2010, 03:23 PM
likeyoumeanit's Avatar
could be, theres no fluid that could have got on the new belt is there?
Old 02-18-2010, 03:28 PM
no fluid it was doing this before hand as i forgot to mention
Old 02-18-2010, 04:58 PM
frozen's Avatar
Vehicle: 2001 Tiburon
Possibly alternator bearings... Stocker should chime in, I think he rebuilt his right?
Old 02-18-2010, 05:09 PM
well i just got back from autozone and had them check it ON THE CAR and it failed the output charge...
so what im going to do is take it off again and take it back to have them test it in their machine and go from there...
im also thinking it could be water pump going
Old 02-18-2010, 05:53 PM
Regit's Avatar
Vehicle: 2000 tib
sounds like a belt slipping at first,or a pully not seated right,but my guess is the altenator not charging/holding a charge..also when you take it off(altenater) check all your connections battery posts,chassis ground etc for solid rust free contact..Ps a bad alt will kill a battery quick!..usually if its a bad waterpump,you'll see it leak out first b4 a noise is heard..usually.., what does the altenator do if you dissconect the battery whilst running?
Old 02-18-2010, 07:13 PM
if the belt is loose or it's not grounded properly it could be keeping it from charging. Just b/c there is no charge doesn't mean it's a bad alternator.
Just as an easy test, add a ground wire going from negative terminal to the alternator. Mine made weird noises when a bolt came loose that grounded it to the engine.
Old 02-18-2010, 07:18 PM
First (next) step is getting it checked, when off the car. It is easy enough to tell if bearings are failing, just spin the rotor by hand. It should spin smoothly but with some minor resistance. If it spins very freely, that's bad. Any noise besides a very slight hiss from bearings spinning in grease is probably bad. Any tactile crunching or grinding is bad.
If it fails the electrical output tests also, you've a good candidate for a core return. 02.gif
Old 02-18-2010, 08:03 PM
if you have to get it replaced, look for one with a lifetime warranty. O'Reilly offers them I believe.
Old 02-19-2010, 06:27 AM
ok guys thanks...going to start this morning...hopefully i can just take oil filter off with out all my oil coming out to get it off
