Alarm + ECU prob
Alarm + ECU prob
Ok so every time i reset my ECU(via battery) my alarm goes off...i tried putting it in valet mode and that didnt stop it.. how can i reset it without setting off my alarm?
OH btw i tried to reset it using the fuse but it no worky..
OH sorry yah as soon as the negative is reconnected it thinks somebody is stealing it and it sets the alarm off
Vehicle: 1997 Tiburon
Thats a safety device that was wired with your alarm system. What alarm system do you have? Also when you reconnect your negative why don't you turn off your alarm and proceed with the reset?
Vehicle: 2004 Acura TL
You can pull the fuse that is under the dash by the driver door. Pull that out and it will cut the power to the ECU. Diffuse any leftovers by depressing the brakes a couple times. Wait a bit and put the fuse back in. Search around for the exact procedure but I think that is it.
<div class='quotetop'>QUOTE (tanc)</div><div class='quotemain'>Thats a safety device that was wired with your alarm system. What alarm system do you have? Also when you reconnect your negative why don't you turn off your alarm and proceed with the reset?</div>
its a precision alarm, dont know what the model is
i do turn it off but its annoying, and today a cop came over and was askin if i needed any help(looking suspicious) and i had to explain what i was doing, and why the alarm kept going off.. its just a PITA and if its ever happened to you and went off right in your ear, you know it is a headache/earache. The siren is right above the battery = right next to my head
