Airbag Light On
Old 01-07-2009, 12:03 AM
fury's Avatar
^^ That explains it, then.
Old 01-07-2009, 08:14 AM
<div class='quotetop'>QUOTE (i8acobra @ Jan 6 2009, 06:19 PM) <{POST_SNAPBACK}></div><div class='quotemain'>The airbag light comes on and stays on anytime you disconnect any part of the airbag system without first disconnecting the battery... even if you don't turn the car on. This is why you need to disconnect your battery anytime you remove your gauge cluster, steering wheel or airbag equipped seats.</div>
Ehh, I've never disconnected my battery in the few dozen times I've taken my cluster out, no airbag light.
If the key is out, you should be good.
