Airbag Light
Vehicle: 2000
i was in my fuse box the other day and pulled the airbag fuse accidentaly. then when i put it back in my airbag light came on and it wont go away. does anyone know why or how to reset it.
a hyundai dealer or automotive shop with a good scanner can clear the code for you.
Try resetting the ECU by disconnecting the battery for 10minutes or less. If you are in the middle of nowhere and can't get to a dealer/motorsports shop, you can remove the bulb from behind the cluster if it bothers you THAT much. Otherwise you're stuck with it.
Just tell them it came on for no reason and you want it back off.
They'll fix it.
As far as I can remember, they can only be turned off by the dealer.
They'll fix it.
