1st Gen Tib projectors...
Vehicle: 98 Hyundai Accent X3
Hey !!
Does anyone know where I can find info on the 1st Gen Tib projector headlights? I have a 98 Accent and originally thought of doing a headlight swap. Then thought more on the retrofit. Then someone over at crookedh.com mentioned I should look into the 1st Gen Tib lights.
I guess the 1st Gen and the X3 Accent headlights are very similar. So I was going to lookin to all possibilities.
Thanks !
I have no problems with fabbing either way. I'm just looking for the best way to achieve the look I want for my ride.
You definitely have your work cut out for you. I would go to a junk yard and see if you can find a 1st gen thats totaled from behind, so you can get the headlights. Otherwise, you'll most likely be paying quite a bit to buy brand new assemblies. I'm not sure how the electrical components will work with an Accents electrical system, especially since the Tib used different bulbs and wattages than an Accent. But it should just be some simple wiring, or even just get an HID kit for high and low beams, and you'll be all set. The hardest part obviously would retro-fitting the lights to fit the front of an Accent. They're alot longer than an Accents, so it's going to take alot of metal and fiberglass fabrication.
Accent:
Tib:
Accent:
Tib:
His accent doesn't have head lights like that. Actually I think the accent you posted is from the UK or Australia? It's def not a USDM x3 for sure.
Vehicle: 2002 Accent
that's a canadian x3. from quebec. that's my guess based on the text on the truck next to it. I think he wanted to retrofit the inside of the lights which will probably be a lot easier.
