What size air compressor is in your garage?
Vehicle: 2005 V6 Tib
I'm looking to buy an air compressor for my garage and am thinking i'll need a minimum 20gal tank but also, what CFM should i be looking for? (seems like all the mainstream compressors are 4-6cfm, and 1-5hp, although i dont know if thats peak or running HP)
I plan on using it for an impact wrench, air ratchet and tire inflation on cars/atv's. (which is why i dont think i could go down to say a 10-13 gal tank)
What size tank do you have and what CFM?
Thanks
Thanks
I've got the Craftsman 33g 6hp compressor. It runs almost every tool just fine except for a die grinder. They use a ton of air continuously. If you plan on running something like a die grinder, you're gonna have to invest in one of the big boy belt driven models.
Get the biggest you can afford.
Things I use with it:
Sand blaster
Die grinder (have to pause every once in a while)
impact
air wrench
air nozzle for sweeping the floor
Paint gun
Sand blaster
impact
air wrench
Paint gun
Mine is 50 gal. 3HP. It has a HUGE poster on one side that says what sorts of tools it will run continuously, intermittently, or not at all well.
edit: don't recall CFM. 13?
27 gallon Campbell Hausfeld. I don't know the cfm or hp off the top of my head. It has met all of my needs. One air cutoff tool I have overtaxes it occasionally if I use it for too long of a stretch.
