Vehicle Winter Mechanical Preparation
Vehicle: 1999 Tiburon FX
SOme quick tips for people who live in winter climates
• Engine Performance - Get engine driveability problems (hard starts, rough idling, stalling, diminished power, etc.) corrected at a good repair shop. Cold weather makes existing problems worse. Replace dirty filters-air, fuel, PCV, etc.
• Fuel - Put a bottle of fuel de-icer in your tank once a month to help keep moisture from freezing in the fuel line. Note that a gas tank which is kept filled helps keep moisture from forming.
• Oil - Change oil with suitable winter rating and oil filter as specified in your manual -- more often (every 3,000 miles or so) if your driving is mostly stop-and-go or consists of frequent short trips. Change oil with suitable winter rating and change oil filter
• Cooling System - The cooling system should be completely flushed and refilled as recommended. The level, condition, and concentration of the coolant should be checked periodically. (A 50/50 mix of anti-freeze and water is usually recommended.)
• Windshield Wipers - Use the right fluid; together with proper wipers, an antifreeze solution will keep your windsield clean at all times Replace old blades. If your climate is harsh, purchase rubber-clad (winter) blades to fight ice build-up. If your wipers are frozen in place, leave them to defrost or use a de-icer, pulling them off can rip the rubber.
• Apply an anti-fogging’ product to windshield; One clear coat creates a moisture absorbent barrier that prevents the formation of condensation. Maintain optimum visibility in humid, rainy, or cold weather conditions, Fog Clear keeps working to maintain optimum visibility. Stock up on windshield washer solvent-you'll be surprised how much you use
• Heater/Defroster - Test heater, rear defrosters and hoses the heater and defroster must be in good working condition for passenger comfort and driver visibility. Carry an ice-scraper.
• Battery - The only accurate way to detect a weak battery is with professional equipment. Routine care: Scrape away corrosion from posts and cable connections; clean all surfaces; re-tighten all connections. If battery caps are removable, check fluid level monthly. Removal of cables can cause damage or loss of data/codes on some newer vehicles. Check your manual.
• Lights - Inspect all lights and bulbs; replace burned out bulbs; periodically clean road grime from all lenses. To prevent scratching, never use a dry rag.
• Exhaust System - Your vehicle should be placed on a lift and the exhaust system examined for leaks. The trunk and floor boards should be inspected for small holes. Exhaust fumes can be deadly.
• Tires - Worn tires will be of little use in winter weather. Examine tires for remaining tread life, uneven wearing, and cupping; check the sidewalls for cuts and nicks. Check tire pressures once a month. Let the tire "cool down" before checking the pressure. Rotate as recommended. Don't forget your spare, and be sure the jack is in good condition.
• Brakes - your brakes; if the brakes are not performing well, the car may pull to one side when stopping.
• WeatherTech™ rubber floor mats or Husky Liners WeatherBeater™ are available for most popular vehicles
