Tools, 6 sided vs 12 sided sockets
Old 11-17-2011 | 02:05 PM
Moto-X-Red's Avatar
Vehicle: 01 Tiburon
Default Tools, 6 sided vs 12 sided sockets
Doing the 5speed swap so finally brought a decent tool set, I got a 1/2 socket drive set.. The sockets that came with it are 12 sided.. but now I keep hearing that 6 sided are best for grip
Are 12sided sockets that bad? Is it only the cheap ones?
Basically I want to hear that they are fine
Old 11-17-2011 | 02:19 PM
03-accent-03's Avatar
Vehicle: 03 Hyundai Accent
6-sided are better. Less chance of rounding corners off bolts. You can use them, just be aware of that fact...
Old 11-17-2011 | 08:01 PM
wheel_of_steel's Avatar
I've only ever rounded one nut using 12 sided spanners, I don't even own 6 sided spanners. I've used em for crank pulleys, exhaust bolts, hub nuts, whatever. I don't think it would be a big problem dude.
Old 11-18-2011 | 01:04 AM
i8acobra's Avatar
Vehicle: '14 Ford F-150
Six point grip better, but 12 point are easier to get on the bolt in hard to get to places.
Old 11-18-2011 | 09:48 AM
I've rounded off several bolts with 12 point sockets. I've only done it when the angle wasn't very good and I couldn't really see what I was doing. But it happened often enough that I only use 6 point now. I reserve the 12 point sockets for 12 point bolts.
Old 11-18-2011 | 11:52 AM
>12 point bolts
