internals 1.8 cams
Old 03-06-2010 | 04:46 PM
ACCENT2.0t's Avatar
Vehicle: 1997 hyundai accent swap 2.0 turbo
Default internals 1.8 cams
ok everyone i have a 1999 tiburon motor and i have a 1999 elantra tranny and my car is a 1997 hyundai accent i have a mits turbo setup with obx turbo headers and evofusion exhaust and tons more im only pushing about 5-6lbs and i heard something about using 1.8 elantra cams in the 2.0l has anyone done this and what improvements are seen hp wise and generally and would it effect my turbo setup for any reason????
Old 03-06-2010 | 06:21 PM
radu_rd2's Avatar
Vehicle: 2006 Pontiac GTO
it's a small but noticeable improvement for N/A
turbocharged, i wouldn't bother, better invest in whatever you need to push a bit more bost
Old 03-07-2010 | 10:36 AM
ACCENT2.0t's Avatar
well im gunna rebuild my motor and i was gunna use the 1.8 cams instead of my 2.0l and ofcourse the forged internals too oh and would i need adjustable cam gears or which gears
Old 03-07-2010 | 05:19 PM
Fintile's Avatar
believe you can swap the 1.8 rods into the 2.0 for lower comp ratio. that would help you to be able to use more boost.
Old 03-09-2010 | 06:39 PM
ACCENT2.0t's Avatar
bump
Old 03-09-2010 | 09:11 PM
just do it then
its a 80 dollar mod and if you have it apart might as well add a little bit of hp
on a NA motor the "gain" seen is that it seems to have top end power pull a little higher up top
you dont need cam gears or anything else
as stated before, instead of spending money on cams, and gears and other "small mods" like that, you will see alot more gains if you build your fuel system up a little more to handle more boost
spend money on mods to add boost and dont worry about any other mod, the stock cams are GREAT for boost
Old 03-10-2010 | 06:08 PM
ACCENT2.0t's Avatar
the exhaust cam is the same and ive read it advances timing by 6degrees so what gains/ difference will that really make and is this really even worth while as anyone done it on a boosted beta yet and i plan on rebuilding my motor with all forged internals this summer and i was gunna do the cam swap while i was at it
Old 03-10-2010 | 06:37 PM
dude...you will not even notice any gains on a turbo engine, save that money and puts towards something that will give you gains...ie aftermarket cams, fuel upgrades, turbo upgrade...something that would actual yield some power
Old 03-10-2010 | 06:42 PM
ACCENT2.0t's Avatar
yea i have plans for aem fuel system stand greddy emanage i already have dsm injectors and a t3 turbo im prolly gunna build up with those hwarange pistons and kspec valves and i have to find some good forged rods i think kspec had some and maybe a water methanol kit (; whoknows im hoping for 350 someday but i may use the cam anyways its only 125 from kspec and any other aftermarket cams are around 500 id rather put that towards m fuel system
Old 03-10-2010 | 07:13 PM
dont bother with those cast pistons man
you can get wiseco FORGED for like 20 bux more
