ECU Removal
Old 02-01-2011 | 09:20 PM
Tony Vendetta's Avatar
Default ECU Removal
So heres the situation. I have my PNP megasquirt ecu on hand. I attempted to remove the ecu, and have removed the 12mm bolts on the ecu bracket. The ecu is loose but something is holding it, can someone please chime in on this?
Old 02-01-2011 | 09:26 PM
HotBlue02's Avatar
Vehicle: 02 Hyundai Accent
What kind of car do you have? How many bolts did you remove? I think my accent had 4 bolts holding it in place.
Old 02-01-2011 | 10:36 PM
The wire harness itself is pretty stout. If you're sure all the bolts are out, you may just need to undo the electrics.
Old 02-06-2011 | 02:57 AM
I have a 98 tiburon fx. Yes your right stocker, the wire harness does seem to make it difficult.
