Bad Voltage Regulator
Old 07-07-2010 | 04:13 PM
My alternator spikes to 19V. Check it out.
<object width="425" height="350"><param name="movie" value="http://www.youtube.com/v/ao0sPoK8w0g"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/ao0sPoK8w0g" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350"></embed></object>
Old 07-07-2010 | 08:21 PM
UrS0NvS's Avatar
better watch that man. we bought a new alt for the dweetmobile and it was pushing 18.4 volts. was blowing headlights out left and right before we finally figured it was the alt.
Old 07-07-2010 | 08:37 PM
Yeah, I was worried too. So i found my old alternator which has a bad coil, and I swapped out the voltage regulator.
The screws were stuck so I ended up using a dremmel to turn the phillips screws into flathead screws.
I unsoldered the wires using a soldering iron and a mega-boost from a small blow torch
It worked well! It's a bit high because it's charging. I drained my battery a bit while I was working.
<object width="425" height="350"><param name="movie" value="http://www.youtube.com/v/S7YoUVaiIcE"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/S7YoUVaiIcE" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350"></embed></object>
Old 07-07-2010 | 09:40 PM
You know you didn't have to unsolder all the big wires on the rectifier side right? Mine was 3 bolts +1 solder joint and the regulator was off.
Did you dress the brushes at all? I used some fine sandpaper on a AA battery and some IPA to clean mine up, but they needed it due to less-than-gentle handling.
Old 07-09-2010 | 04:48 PM
From the schematics I can't tell for sure, but are you sure that was the voltage regulator and not just the brushes?
I cleaned the post and the brushes with electrical cleaner, but I was not going to risk
messing up the contact surface by cleaning it. Even if it is just a little.
Old 07-09-2010 | 09:35 PM
On our cars' alternators, the plastic part holds the brushes, their braided wires and springs, *and* the regulator. The stuff on the other side (the not-plastic parts on the back of the alternator) varies in appearance, from "holy **** made in china" to "hey nice heat sink you got there" but the basic idea is a half-dozen diodes for the regulator to get DC it can use.
I only found out a AA battery is the right size AFTER the counter jockey said my regulator wasn't making any output voltage at all. If you get the brushes even a little bit out of shape, the sliprings won't be in electrical contact. Spray-on cleaner is probably your best bet unless you don't care what happens to the alternator.
For those who are curious, here is a primer on how an alternator works. If you don't understand basic electricity, this may be a bid over your head, but here it is: http://www.alternatorparts.com/under...lternators.htm
Misc. rectifier pictures: http://www.nationsautoelectric.com/rectifiers.html
Old 07-09-2010 | 11:04 PM
howabout voltage regulators? know any sources for tiburons?
Old 07-10-2010 | 09:56 PM
I would call Texas Alternator & Starter Service (I think that's their name), the local shop in Austin if I thought I needed a regulator. . . but I think my spare alternator on the garage shelf has good electronics.
Old 07-10-2010 | 10:37 PM
I think the one which I just swapped in has a problem. It seems to slowly regulate the voltage to off until I give it a good rev. I will check around first, but I will keep that in mind
Old 07-15-2010 | 05:08 PM
After a few days my regulator started dieing, but the other way, it decreases in power rather then increases. I decided to rebuild my Alternator. I got onto HyundaiPartsOnline.com and ordered 2 bearings and 2 voltage regultors.
I also ordered 2 bearings.
