AutoCross Hyundai's
Old 02-03-2003 | 01:57 AM
BV1's Avatar
BV1
Default AutoCross Hyundai's
Just curious who all autocross's their cars here. I do, I was hoping Random would start a forum specifically for that event. I am the only one who does it consistently here in Winniopeg, but I wanted to know anyone else's experience with Tire setups, pressures, KYB, Koni, 225's, R-compounds, over steer, under steer etc.
Is anyone else for this?
-Steve
Old 02-03-2003 | 02:07 AM
Hootie's Avatar
There should be a local SCCA chapter in your area.
As for tire setups and such, I run stock wheels, (tire pressure at max), with the Eibach Pro-kit.
Old 02-03-2003 | 03:35 AM
Skitzo's Avatar
I haven't had a chance to do anything with my suspension yet, but I do AutoX.
Right now, stock tires between 40-44psi.
I did good at the last event...I started with a 49.896 and ended with a 46.016.
I was very happy.
Old 02-03-2003 | 03:59 AM
stickshift's Avatar
Vehicle: 2000 Tiburon
I plan to get into AutoX seriously this summer. The local motorsports club here holds events all through the summer.
I've only actually done it once before, but it was so much damn fun, and I should have my car set up nicely for this season.
Old 02-03-2003 | 05:21 AM
Orca's Avatar
Hootie:
Actually, that's not true north of the 49th parallel, i.e. outside of America. For Canadian info, check out http://www.asncanada.com/index2.html wink
Old 02-03-2003 | 06:53 AM
KayJai's Avatar
BV1:
-Steve
I found that when I ran 44psi up front and 38psi in the rear was a good setup for me. Anymore than 38psi, the backend was too loose. But then again, I have 205/50/15's, not your mamouth 225's
moon
Old 02-03-2003 | 08:29 AM
Viper966's Avatar
i autoX the crap outta my automatic tib.. i do farily well 2, im faster than most of the WRX's and all hondas that compete in the novice section, and im usually PAX indexed top 20 every event (15 are pro)
so im ahppy with that with just 17's and a strut bar
Old 02-03-2003 | 12:10 PM
sharkey9883's Avatar
i autoX, fun as hell, ain't it? speed is all and fun, but hairpin turns and squelching stops are where the real fun is
Old 02-03-2003 | 12:35 PM
blue2000's Avatar
Vehicle: 2K Tib
I autocross too, though I only started last season. I was hoping to do all the events for my local club this year but it looks like I'm going to miss the first half, what with the Iraq stuff going on.
Old 02-03-2003 | 01:24 PM
BV1's Avatar
BV1
Wow, thanks guys, alot of responses. I run my tires at 44 psi, right at the max, they grip well enough but the suspension takes a dump. I got a vid on my page if you are interested.
I am not sure if I will continue to dump money into it or get a new one, we will see.
-Steve
