Yellow Gooo Inside Of The Valve Cover
then change your water pump, if its actually your water pump making noise.
also, if you want people to help by using your pics, learn how to focus the pics.. i can barely tell whats going on there.
Yes, it's condensation mixed with oil in the valve cover. If you feel that strongly about it, take off the valve cover and clean it, that's what I did.
Has nothing to do with your water pump or head gasket.
My engine does the same thing. Not as bad on synthetic for some reason, but it should only build up around the oil cap, just clean it off like what everyone else said and call it a day.
