XD Cam install
Vehicle: 99 Tib
XD Cam install
what all should I do when i install the cam is there any tunning involved should I mess with the timing or anything what else should I buy?
you need nothing else. well, that's not true. you need a torque wrench with small torque values for the cam journal bolts, (they tend to snap easily when overtightened just a bit) and you should get a new camcover gasket. most likely you will pry yours off with a screwdriver, i did. so you don't want leaks. but i did the install months ago without new journal bolts or a torquewrench, i just was REAL REAL careful. doesn't mean its a good idea, but hey, im poor
If you searched, you would have found this site which gives you step by step procedures on how to install it and what parts you'll need.
http://webhome.idirect.com/~trini/car/cam.html
