Wiring diagram
Vehicle: 2001 Tiburon
Wiring diagram
Can someone throw up the wiring diagram for the SAFC and the ECU. Did a search found the table with all the wires but coulding find the one of the ECU harness. Also how do you set the SAFC to just view, because I don't want to adjust anything until I get on a dyno. Thanks in advance
from hyundai webtech
I imagine that as long as you don't make any adjustments to the A/F settings, you'll be able to monitor the settings (check the manual for getting diff parameters etc.) with those *non-adjusted* settings.
