What's the function of resonator that is under air intake?
#21
Guest
Posts: n/a
the only thing I did was took out my whole stock intake up to the manifold/air temp sensor and attached a 2 1/2" to 3" reducer to that section followed by a 90 degree flexible dryer hose elbow then attached a Hyper industries cone to it. Total price of the mod was about $45 USD here in hawaii. The most expensive part of it was the $25 filter cone. Its not a cold air filter only acting like a short ram right now. Until I can get a hole of a 3" dryer hose that fits over the reducer so I can extend it and put the cone under my battery. Dont know what horse power gaind I got but took about 3-4 tenths off my 1/4 mi time. Seen here: http://rain.prohosting.com/hawaiibu/Timeslips.html. Ill have pics as soon as I get a hold of another digital camera.
#22
Originally posted by Silver_Tibby:
Cool. Thanx
Cool. Thanx
Well, I didn't get a chance to pull that puppy out and get some pictures done this weekend. I'll try and do it tonight. Then tack on another day for getting the film processed. I should have pics up by this weekend. Dang...all this anticipation for such underwhelming pictures. wink.gif
#23
Hey Iago, if I understood you correctly, what you did was to remove the resonator and leave the air intake... right?
If so, what did you do to the hole that connected air intake to resonator?
And after doing this mod, did you feel any power gain?
hawaiibullrider, I wish I could do that kind of mod. I'm just too lazy to buy all parts
[ September 11, 2001: Message edited by: Silver_Tibby ]
#25
Guest
Posts: n/a
Only took me about a half an hour to instal the parts and about an hour to get them all.
#26
You are correct in your understanding. The resonators are gone, but the intake was replaced. For the sake of preventing unnecessary hot / dusty air in, I wrapped electrical tape over the holes to seal them up. This will cause the engine to work slightly harder to breathe in, but I figured that the debate between cold-but-harder-to-get air vs. hot-and-dirty-but-easy-to-draw air would be minor.
I don't know if there really WAS a power gain, or if I just *thought* I felt a gain, but there may have been a minor increase in HP. There was a DEFINITE increase in performance when I had taken everything out, resonator, intake, and all, but that only lasted about 20 minutes until the radiator kicked on. Then I felt like I had LOST power over the stock setup. If nothing else, I took out some superfluous weight and helped streamline the intake of air into the engine. As you will see when I get the pictures developed and posted, the stock air intake is still somewhat restrictive, and when I install my bored IM and throttle body, I'll probably replace the rest of it with something else.
#27
I think I will just wait til this X-Mas to install CAI... since I'm going to university this Friday, I think I should care more about GP improvement than car HP improvement
And about that hour of shopping... do you really think that lazy people can shop for entire hour!!! rolleyes.gif
#28
I'm not sure, but if you used this "snorkus" method, wouldn't you be more prone to hydrolocking your engine, especially if you ran the dryer tubing down under the fender where the tire would throw water right at it? I dunno a lot about this, but from my understanding you just remove the air intake, the resonator, then run a dryer tube from the hole in the stock airbox that the stock air intake was in down into the fender where it can suck in cooler air. (Basically a cheap CAI.) Should there be some mesh or something on the end of the dryer tube to prevent sucking up water?
#29
Mesh won't stop water, unless it's very fine, in which case it's posing an equally big restriction to airflow. Hydrolock is still a very minimal risk, because there are drain holes in the stock air box. The odds of sucking up SO MUCH WATER that these drain holes can't dump it out fast enough is tiny. You'd have to be in SUCH a deep puddle that hydrolock would hopefully no longer be your biggest concern...getting your ass out of the river before your car goes under would be!
#30
With the "snorkus" setup. You would not Hydrolock even if you dunked the end of the snorkus in water.
The stock air filter is HUGE. About 5" by 8". That is a HELL of a lot of surface area. Add more surface area for the pleats. the more surface area/larger the chamber the more the pressure drops. There are also air holes in the stock airbox to allow air in and water out. If you dunked the "snorkus" end in water, the engine would just suck the majority of the air through those holes.
