What Am I? (hose)
Old 05-27-2007 | 08:45 AM
BlizagaXx's Avatar
Vehicle: car
I was only driving with it off for a couple minutes I assume... My car idled all funky and died. I then fixed it, so that should be fine. As far as the IAC, if you can do better that 25 shipped, lol.
Old 05-27-2007 | 01:41 PM
driftkid77's Avatar
can you damage the it IAC if you clean it with brake cleaner?
Old 05-29-2007 | 12:24 PM
Loneshark's Avatar
Vehicle: 2000 Tiburon
nope, I thought mine went bad, so i went to the junkyard, and errr umm, "borrowed" one from a beta motor, and i put it in and still had the same problem, a rolling idle, so i read around, and someone said brake cleaner, but then to let it dry thouroghly after.
I sprayed my original one, and it worked perfect.
I cleaned and tested the other one too, just to make sure it was good.
