VHR clutch owners...
Old 07-12-2004, 11:18 PM
  #31
OdessitPashka's Avatar
so, how can someone race with this damn clutch? wouldnt you be spinnin your tires all the time???
Old 07-13-2004, 06:28 AM
  #32
tibwrcsbj's Avatar
QUOTE (01roller)
aight so you can engage 1st gear at about 1500 rpm, i thought that most couldnt get it till about 3000 rpm??
the 3k was where i needed to shift during the intitial (0-300 miles) break - in period. now its down usually just below 1.5k, sometimes as low as 1k.
Old 07-13-2004, 09:47 AM
  #33
Loneshark's Avatar
Vehicle: 2000 Tiburon
Default *New Product Alert!* Yaya Engine Mounts!!!
QUOTE (OdessitPashka)
yea if your riding on a hard compound tire, but if you throw some slicks on there, and lower the tire pressure, youll get some good grip, but then your really going to have to worry about your axles getting tore up and the diff. due to the added stickiness of the tires
Old 07-13-2004, 10:15 AM
  #34
so this clutch and stock tires or even aftermarket that are not slicks would be useless?
Old 07-13-2004, 10:38 AM
  #35
No.
I doubt anyone here with this clutch is running Slicks.
Old 07-13-2004, 10:40 AM
  #36
well, whats the point of having this clutch if you don't race and have slicks? I mean, you keep spinning your tires almost every time you start driving, and then when you go to the track you would just get really bad traction? Am I wrong?
Old 07-13-2004, 11:09 AM
  #37
I don't race, I've got that clutch.
It's a good setup all around, and it'll be good for when I get a turbo too.
Once you learn how to drive with a high power clutch like that, you won't spin your tires all the time. Half of it is the Flywheel.
Old 07-13-2004, 11:26 AM
  #38
I see. Well, once I get my turbo in, I will need to change my clutch, so I might as well get this one, and what do you mean by, half of it is the flywheel?
Old 07-13-2004, 11:36 AM
  #39
Lightweight flywheels.
Next time you drive, watch your RPM meter. Then imagine it dropping like a rock when you let off the gas.
Old 07-13-2004, 11:37 AM
  #40
What would happen if my rpms went down really fast?
