very loud screeching noise when turning right
Vehicle: 2000 Tiburon
hey all, i have an issue with the car that i hope you guys can help with. i noticed yesterday that anytime i make a right turn, theres a really loud screeching noise coming from the car. it does it whether the car is warmed up or cold. my first thought was that maybe the belts were loose. i checked them out and everything is good on them. no wear and theyre nice and tight on the pulleys. i checked power steering fluid and that seems to be fine too.
it only makes the noise when i turn right. when i turn left its ok. any ideas what could be causing this?
If it makes the noise when the car is not moving:
With the engine running and the hood up, have someone crank the wheel hard all the way to the right. Have a GOOD look at the power steering and alternator belts.
power steering/alternator belt usually. it might look tight, but it'll make noise if it's not tight enough. the alternator has a pivot on it. it's hard but i took a crowbar and tightened it that way, then screwed it some more to tighten it more. i'm sure there's some factory setting on it though, but i don't know that much.
