Urgent!! SAFC question
Vehicle: 2000 Tiburon
Which wiring diagram do I use:
http://www.teamsr.org/cgi-bin/ultimatebb.c...c;f=16;t=001549
There is one that looks to be for the AU model(the one Random posted).
Then there is one that Azzy just wrote.
But here is the catch, the pin numbers don't match between those two. I am running a US spec tiburon, do I still use the chart for the wiring or Azzy's post.
Please help asap
[ August 15, 2002, 11:41 AM: Message edited by: My2000tibby ]
Please help asap
Well, think about it.
You are running a US Spec tiburon...so you would of course use the US spec wirring.
AU - is for aussie, but I am not sure if the Aussie wirring is for the european and canada wiring.
But thats the thing, is what Azzy posted for us spec or what. I am very confused. I already started wiring it according to the AU chart. So it don't know if i need to change it or what.
Someone please help. I am stuck
please search for specific connections using webtech... i did that to make sense of the two differnt lists, but i'm at work now, and don't have anything in front of me. azzy's numbers are actually basically the same as the chart with like one or two exceptions. i think he used different grounds, but all the important ones are the same. the webtech diagrams actually show you the pin numbers for the specific connections. search for things like tachometer and oxygen sensor on webtech, and you'll see what i mean
My2000tibby:
ANy more info would be great, thanks
OK, home now. I definitely used the pins shown on the US column of that link you originally posted. i have my printouts from webtech, and the pins i circled all match up with the functions shown on the US-spec list. i even jotted the colors from my harness down so i could double check my counting as i was splicing. there are SEVERAL grounds in the harness, i have at least three on my printouts. in my harness pin 55 seemed to have a nice thick wire attached, so i used that one as the ground, so i'd be sure to get a nice bite.
