Transmission
So with the 02 Elantra tranny I won't have to worry about grinding abit of the back near the tranny mount?
And the cables should all be fine and not need any adjustment?
And my LSD and Clutch/Flywheel will work with all tranny's from 98-04?
you wont have to shave the 02 elantra tranny
from i remember.. the cables fit fine... and did not need to be adjusted
Your LSD will fit, your clutch will fit... the flywheel MIGHT. Remember the crank changed mid year in 99.
So there still is a gearing difference between the 02 elantra tranny and 04 tiburon tranny even though they are both beta2's?
Also I talked to the scrap yard again and the 04 tiburon tranny has a dent/hole in the casepan. But they said there doesn't look to be any other damage and said I could return it if there is any problems when I open it up to install the LSD. So I right of the bat I would need a new case because the one from my tranny will not fit?
Either way my mechanic is good freinds with the workers from the scrap yard. He had a look at it and said it doesn't look like a big deal. And we will see if there is anyting when we crack it open.
What is the better tranny to go with hear 02 elantra or 04 tib?
I don't like the idea of having problems with the linkages.
I need some more opinions.
Thanks Guys
Thanks Guys
Well I got the car back to town and got the tranny removed
Here is a pic of the tranny
I picked up an 02 Elantra tranny. It looks to be pretty much exactly the same except for a few small things.
I will post some more pics up in the next couple days of taking the Tranny apart and installing my LSD.
QUOTE (OdessitPashka @ Sep 26 2005, 03:07 PM)
Actually, I believe that 3rd gear is a lot longer in beta2 cars. They shift to 4th around 90mph...
So do I...
