Took off the exhaust manifold..ew
I took of my cracked exhaust manifold today, going to take it to weld the crack temporarly, anyways after I took it off It looked gross in each piston exhaust exit. Is that normal or does it look a bit to clogged? How do I clean it and what else do you engine guys see weird in that pic that I don't
Cracked Exhaust Manifold
HEy bro, i feel your pain, i did the exact same thing with my exhause manifold when i flew onto a 6" curb, getting a new one makes no sense, cheaper to just weld it. Btw, like the sound with it leaking? lol, mine leaked just a tiny tiny crack but the sound was like a HArley Davidson 2000CC motercycle ROARING!!!!!!
(Dear Redz this posts refers to the thread due to the fact that i mention the exhaust manifold as a problem i also had and am explaining to Tanc what his best option is. please dont ban me for this post if you find it not pertaining to the subject, thank you)
Vehicle: 2004 Acura TL
QUOTE (Kit-Fox)
Seriously Kit-Fox it's 5h!zzz like that that will get you banned.
I just noticed that is the engine exhaust port. I thought it was the manifold at first. I looks kinda scary. Maybe running too rich could cause that. When I was learning how to drive stick, it was mentioned to me that it is not good to shift really low in the rpm band due to carbon build up. I never really gave it a second thought until now. That might be what it is. ????
Eww... running a little rich I think. And people say that a few crinkles in piping is going to slow up exhaust speed. smile.gif That usually happens if there is a CEL and the ECU decides to dump fuel to be safe or at low RPM WOT. The velocity from high RPM WOT can clear out some of it, but I think it needs a little help in your case.
You think thats bad, wait until you tear down your engine or if you replace your IM. Carbon all over the combustion chambers, oil sitting in the IM manifold, etc... its all so icky.
What might also help is a fuel tuner. I don't know about Tibbies, but on my GSX when I first got it, the A/F was horrible at 6000RPM. I think I was around 10:1 Air/Fuel. Waaaaaay too much fuel.
BTW, could someone enlighten me on the Tiburon ECU not holding a tune? For how long does this last, and I'm assuming that resetting the ECU changes this and gets rid of it not holding it. (SAFC II keeps settings when you reset engine, so no new tuning required...)
QUOTE (Kit-Fox)
I'm not gonna ban you man. Just cut out the BS in EVERY thread. You can have some fun bro, but seriously, take some Valium, and try to help some, like in this thread.
Keep it cool my mang.
Jackass.
