Ticking Sound
Ok well I will go check the wingnut now, when the radiator cools down, and tighten it. Also another bit of information that might help, I can let the car sit on and everything and it will not heat up only when I am actually driving.
ok I will keep everything updated and you dont even want to know the whole story on the front bumper situation. I dont think I am even going to get the ixion front bc they are having too many problems with it, so I will probably end up with a front that I dont even really care for.
Ok checked the nut it was tight, it is still leaking so once I get the compression test done, I hope it just proves it was the radiator and not the water pump
