Ticking Noise, Oil Light
Old 03-24-2007 | 08:04 AM
NY Turbulance's Avatar
i bet you it works
Old 03-25-2007 | 08:26 AM
daniel_depetro's Avatar
What did you find out?
Old 03-29-2007 | 04:27 PM
tiburon354's Avatar
UPDATE:
well i picked up a genuine oil filter from the hyundai dealership saturday. a mechanic there said that although he hasnt been working there all that long, he's already seen about 5 or 6 tibs with the same problem. oil light comes on, knocking noise ,no oil pressure. he said the filter change fixed all of them. so i brought the filter home, changed it and have been driving it since saturday and theres been no problem since. i guess it was the filter. thanks for all the help guys. cool.gif
but today i noticed my right front wheel seems to be making a weird noise, usually when i take right turns is when its most noticeable. i had the tie rod and lower ball joint changed in november, so i dont think its that. does anybody know what it could be? i feel like smashing that car into pieces with a sledgehammer and getting it over with. mad.gif
Old 03-29-2007 | 06:14 PM
rallyman's Avatar
Describe the sound. Is it a clicking sound when turning (CV joint), a grinding sound (wheel bearing) or something else?
Old 03-29-2007 | 06:27 PM
tiburon354's Avatar
i did some searching and think its the cv joint. ill know for sure tomorrow.
Old 03-29-2007 | 09:42 PM
well i picked up OEM oil filter too...i did not have the same problem you did but im going to see if my oil pressure on my gauge is affected by the OEM one, if so i will just go to dealership and get two of them next month to have in the closet
Old 11-03-2007 | 02:55 PM
Bullfrog's Avatar
Vehicle: 2001 Tiburon
How much those Dealer filters cost per filter?
Old 11-03-2007 | 03:11 PM
Most likely is not the cv joint. Wheel bearing would be your best bet. Does it change when turning one way? And I dont think wheel bearing is a grind. More of a whining sound
Old 11-03-2007 | 03:53 PM
^^ I wish people would suggest tighting the wheel lugs before suggesting a bad wheel bearing.
And don't forget the 25ish MM wheel hub castle nut. You can get to it with the wheel off and a BFW (big frickin' wrench). If a BFW dosn't work, try using the BFW with a BFH.
