Throttle Response
Throttle Response
When i touch my gas pedal, to take off from a stop. The engine hesitates just a bit before reving. This causes the car to kinda stutter when I put my car in 1st. What can I do to make the response better?
Guest
Posts: n/a
When is the last time you changed your spark plugs/wires? You may have also gotten a bad batch of gas as well. Are you talking when you are driving normal or gunning it? If you are gunning it mine does the same thing if I let the RPM drop below 3000RPM which is normal. Hope this helps.
