Those With Newly Built Forged Engines...
Old 09-19-2005 | 05:44 PM
  #41
Mad_john's Avatar
what a great find.... order one kit now even 2 used my mons name.... nana.gif
Old 09-19-2005 | 06:12 PM
  #42
JonGTR's Avatar
I picked up the plug from Advance today. It was only $3.
Old 09-21-2005 | 09:53 PM
  #43
Denisst99's Avatar
QUOTE (JonGTR @ Sep 19 2005, 02:39 PM)
it could be that they didn't check the gap in the rings or the bore size. If they aren't wide enough, then when the piston expands, the rings get eaten..
ring gap too narrow won't make the ring "eat themselves. .they will simply "seize" in the cylinders when the heat will make them expand,
bearing shavings? i doubt it it's non-magnetic material.. unless you eaten the to the point the crank is running on the steel "holder"
