Those With Newly Built Forged Engines...
my wife has a z24 and her car came with one... I just never took the time too look at autozone. tongue.gif
i just saw the pic and was like, what! other peoples came with it?? anyways jaws thats not looking good. isn't compression supposed to be up in the 190's? .... or is this a low compression engine?
I have low compression Wiseco pistons in there.
The compression numbers are consistent,... so im not worried about that. The gauge was also old, so im pretty sure i can hit 170+ on a newer gauge.
QUOTE (TiburonWao @ Sep 8 2005, 02:28 PM)
Exellent manifold.....
Thank you..
Ive been wanting that manifold ever since i saw it like 3 years ago.
Magnetic plugs are VERY useful...
QUOTE (Jaws021 @ Sep 8 2005, 04:25 PM)
turbo gets here tomorrow
Yes.. im staying with an internal wastegate.. with the turbo im using, i dont expect to push that much PSI to get where i want to go wink1.gif
As far as the head polishing.. it was a b****.. but WELL worth it..
thanx guys
Gary do you have a magnetic plug?
thanx guys
Yes I have a magetic plug.
I never got anything on mine.
When the motor was first started after the rebuild we let the car idle for about 20 Mins then changed the oil/filter. Then I did 500 kms changed oil/filter and then did 1000 kms and changed the oil/filter. Cut open the oil filter regulary to check for debrees so far so good.
What turbo are you using?
DEBRIS!
Ok, nitpick over...
I have had several engines built over the years.. and NEVER had a problem with junk in the oil... I hope you are not letting the same person build all your engines?
Ok, nitpick over...
damn.. if I had an engine built by a shop and it blew up as quickly as yours do.. I would be damned if I would go back.. especially if it happened again.
How many times do you have to get hit in the head before you learn to duck?
