Switching a MAP to MAF *RED*
Actually, the main pulley is the same between the two blocks. However, you may have problems with the water pump pulley... The pulley is keyed so that it bolts onto the pump only one way; however the key placement on my '97 pump shaft was different than the key placement on my '98 pump shaft. I had to cut the pulley slightly to make my own notch for the '97 pulley to fit onto the '98 pump wink
The wiring harness may indeed be different, and we DO now know (thanks SCCA Elantra) that the intake manifold and TB could be different. If you have that "different" intake manifold and TB, then you should use it. Otherwise you're inviting more problems...
Random would probably be the best bet to offer help, as he's closer and can check it out for ya.
Red:
The wiring harness may indeed be different.
DOH!!!The wiring harness may indeed be different.
the IM and TB are different
Ive seen the MAP sensor thingy sticking out of the IM
The coils are a bit different too,... well atleast the wiring harness are,...
This is going to be a bitch when i do the swap
Im going to see if i can haul the engine to randoms house for a quick compare and contrast
