Stock IM measurement
Old 08-03-2004, 05:15 PM
Blu_Drgn's Avatar
Location: Lillington, NC & Maryville, TN when I can get there
Default Re: Recalibrate The Speedo
Just a quick question. Does anyone just happen to know off hand what size the stock im measurement is? the reason i'm asking is because i want a BBTB but am not sure if i need to change out my IM also. any info would be greatly appreciated by a *NEWBIE*. thanx
Old 08-03-2004, 05:18 PM
Default Stock IM measurement
Welcome to the site, actually, you don't need to change out your IM, just bore the opening more. The stock is at 54MM I belive.
Or you can get the airram IM.
javageek's Avatar
Default Re: Stock IM measurement
You will have to get it matched if you want to see gains. I think the stock TB and IM are 54mm.
Doh' Posted at the same time as Redz.
Welcome to the site! I see you are from No Hope Pope.
Old 08-03-2004, 05:55 PM
wattsup4800's Avatar
Default Re: WTB: Stock RD2 Wheels
if you can afford the AIR ram IM
dont hesitate and get it
other wise the BBTB alone shows some good gains
Old 08-03-2004, 06:14 PM
54mm for the stock throttle body?
I thought the stock one was only 50mm... mmm... guess not.
Old 08-03-2004, 07:23 PM
Default Re: North East Meet Aug 21/22 ??
Nope, 54. Most of the BBTB's are 58MM, the Rside is 59-61MM and the Turbo's are 70MM.
Old 08-03-2004, 07:43 PM
Default Re: Custom Short Shifter.
i thought rside was discontinu'in the 70mm
Old 08-03-2004, 07:50 PM
Default Inbox and Outbox for Private Messages
Are Oz spec throttle bodies different to the US spec???
On this site they reckon they're 50mm stock... Their modified BBTBs are "bored out to 55mm"!
http://www.performancestylingcentre.com.au/
Are they just mistaken? Or, as the US spec stock TB is 54mm, would I see performance gains (albeit minimal) with just a straight swap of stock throttle bodies (Oz/US) ???
With all of you guys having BBTBs I should be able to pick one up pretty cheaply...
Any thoughts?
Old 08-03-2004, 07:53 PM
QUOTE (wattsup4800)
No, they just can't afford to do another run of 100 of them without some backing. Wanna lend them 1,000,000 won?
QUOTE (OzFxCoupe)
Any thoughts?
It's possible I guess. Depends on the TB really, you sure you were reading for a 2.0? I can't see Hyundai making different ones.
Old 08-03-2004, 08:33 PM
Default Re: Zefiro Gen I frp vent hood
According to them, both 1.8L & 2.0L TBs are the same... so, yeah I'm sure.
