Spark Plug Gap
No matter what gapping method you use, best to keep the gap within factory spec, as a larger gap will put more strain on the ignition coil, eventually causing it to fail. Spark plugs are cheap and easy to replace and gap, ignition coils are not!
Rich:
Hey guys, i just replaced my spark plugs w/ some Denso's (auto-zone didn't carry NGK sad.gif and didn't want to use champion plugs). I'm not sure if they're good, better, or best but the guy @ A/Z said they're made by NGK...anyway, the owner's manual said to gap the plug about.0039 -.0042 inches. Is there a 'performance' gapping method? I just gapped them @ .0040.
I'm unsure if i've been riding around on really old pugs or the Densos are awesome, but i felt a BIG difference in torque/hp and throttle response.
Very happy with this and i recommend any1 to replace their plugs!
Rich
Take them out. You will eat thin within 20,000 miles. I had Bosch in mine, and the mechanic at the dealership said NGK is the best for Hyundais. Anything else wears out.
Rich
I learned of this process from "Modern Engine Tuning" by A. Graham Bell.
In testing on my turbo tibby, it didn't seem to help HP or detonation, but gas mileage went up by about 2-3 MPG.
Do it to a new set of plugs. The earth electrode can be rather weak after the plug has been used, and it may "snap off" while you try to bend it into the proper position.
Anyone care to guess how I know?
For those of you who use "ordinary" plugs. Every 5000 miles or so, yank your plugs and file down the sides, end, and bottom of the earth electrode with a small metal file. Just remove enough material to expose new metal, don't actually grind anything away. Ditto for the round positive electrode in the center.
Just make sure you re-gap the plugs when done.
Basically this process exposes "new" "fresh" metal for the spark to jump across. It's like having new plugs every 5000 miles.
Random:
DUDE! Thank you so much you just saved me a boatload of $$$$$$!!!!! smile.gif smile.gif
