SafC-II
SafC-II
http://www.takakaira.com/asp/template.asp?id=815&cat=2
12 ponits of change compared to 6(?) on the old
Knock meter
LEss digital buttons to futz with...
wonder how hard the wire up will be?
Knock meter
WOW!
This is truely an amazing upgrade considering you have extra NE points which you can set and the Knock feature as well
I hope the wiring is the same as the standard AFC.Im thinking there might just be an extra wire to tap into your ECU hardness for the Knock sensor feature.Cant wait to see this unit on teh market in the US and Canada!
