Random: Best wires/plugs
I did a search, I found your not a big fan of NOLOGY or capacitor type wires. What plugs/wires do you reccomend? Have you ever seen dynos that support claims a wire manufacturer makes?
Thanks,
-Steve
Thanks,
-Steve
Just to throw in my advise...I bought Platinum plugs thinking it would help me out because I am using Nitrious...I was wrong they were awsome at first I could really tell the difference and then it totally screwed my engine up when I slam on the gas the car would just sit there and sputter took plugs out and they were charcoll...just my advise...
veilsidetib00:
i hope you weren't using normal temp range plugs with nitrous. they make plugs designed to work in different operating temp brackets for different applications. i'm pretty sure that with nitrous you should be using something other than stock-ranged plugs.
The Magnacore KV85's come very highly recommended from quite a few folks on the forums... All the forced induction tibbies I know of (Random, Onpol, Chris H, etc) all use them with great success.
Just like you saw on their website, they don't claim anything fancy. But they don't need to; they work smile.gif
Yeah, they're like $80 a set for the Tiburon. I ordered a set from the local speedshop for $95. I paid more locally because I like to support the local guys when I can, which is almost never when buying Hyundai parts hehehe...
I figure a set of these wires paired with a set of MSD DIS coils to replace the stockers and I'll have all the ignition I ever need.
I also like Magnacores. But I also have been impressed with NGK.
I constantly change plugs on the RX-7. Either fresh ones or race then street plugs.... anyways, it's hard to remove the wires without yanking on them. I have destroyed several plug wire sets... the connector seperates from the wire. The Magnacores lasted the longest and my most recent wire set, NGK's are holding up fine. These are all 8 mm - 11 mm wires... not that it really makes much of a difference.
