QUICK QUESTION!
QUICK QUESTION!
Alright, for real guys, need this information ASAP, 2001 Tiburon, replacing BBTB, 2 hoses that seem to not have anywhere to go...where do I put em? Need it as fast as possible, have work in the morning and am doing it at the moment, alright thanks in advance! (Btw no search comments cause I mean i dont even have the time to search for this stuff)
Alright got that, BUT NOW I GOT ANOTHER PROBLEM! AGH!, gotta get this fast so i can get some actual sleep....ok the outside cable? (closest to the windshield) what the heck is it? Also is it better to have the wires loose or tight, because i had em really tight, and as soon as i turn on my car, BOOM it just starts zooming through the RPMS IN PARK! AGH! at 12:00 in the morning my neighbors were not happy lets just say that.
K i loosened em up a bit...roared down an open street, and was doing fine right...all of a sudden....i try to slow down...pressing the break...still going...pressing harder, still going, slam the breaks...nothing. Put it into park, nearly redline and kill my car dead. Shut it off in time...push my car home. sad.gif sad.gif sad.gif The things i do for love...now i gotta drive my damn CR-V to work. I feel so dirty...anyway anymore answers would be GREATLY appreciated. (Btw for the time being i have the outside cable (closest to windshield) unhooked, don't know what that might do...but yeh...alright then...thanks in advance.
Alright You have (sounds Like) a vacum Leak.
Lossen them up more.. Also make sure (visualy) that the TB is clsoing all the way.. If it is open even a little you will lose the Vacume of the IM and boom no breaks. Check All connections for vacume leaks. Again they can all effect breaks.
That cable you were asking about is the throttle cable, connected directly to your gas pedal... When you tightened it, you made the car 'think' that you were applying the gas. You have to readjust the cable when you put the new throttle body in place. Put your car in park.... Turn on the ignition, the tachometer should read about 1 and a quarter to 1 and a half rpm. If its higher, loosen that cable so the tach reads properly, if its lower, tighten it. Hope this helps...
wink
wink
