Question About Crank
Hey Random or Red or anyone else that might know.
I was wondering before I try and set this SMT5 back up once I get my new ECU tomorrow. I know that the 1.6L Alpha uses 120 teeth with 4 teeth missing (or that was what I was told) The SMT5 will only go up to 60 Teeth and 2 teeth missing. Would I be able to use this setting and not blow this new ECU or my engine. Also the unit wants to know how many teeth per firing (i.e. 60 teeth/cyclinder on a 120 teeth crank) Once again the most that I can do is 60. If I am able to use the 60-2 would I be able to use 30 teeth per firing or would I have to set it up as the right number of 60? I know, I know, oo many freakin question!
It should be 60 and 2. The SMT-5 might not like the stock Crank Position sensor though.
[ December 17, 2002, 06:43 AM: Message edited by: Random ]
I don't know for 100% sure on the Accent, but if it's a Motronic sensor, then it's a 60-2 (sixty teeth, two missing) sensor. Thus, it's 30 teeth per cylinder fire, and tooth 6 is TDC for cylinder one.
Thank you, Thank you, Thank you gentleman!!!!!!!!!!!!!!!! It's alive!!!!!! And it's actually reading the right RPMs for once I'm in the process of doing a write up on the install to submit back to PerfectPower, once I complete it I will post it here if that's alright with you.
Once again Thanks!!!!!!!!!!!!!!!!!
Lobert:
I told ya!
