Putting in a Apexi Super AFC
I am going to be putting in a Super AFC in my Scoupe by the end of the week. If anyone has put one in a early model Accent please let me know if you have any info on the wiring. Thanks
I just got one too... I have yet to install it. Azzy is making me paranoid! I think I will run it rich just to be sure, at least until its tuned properly. No one in winnipeg even knows what it is! grr
-Steve
-Steve
i wouldnt subtract more than 4% of your fuel @ any given point. that *should* keep you from blowing anything up, increast perfornamce, as well as save some gas. -- untill you can have it properly tuned.
Actually I have an S-AFC on mine plus I got a turbo timer from APEXi that reads O2 sensor voltage, & A/F ratio as well (plus I had already installed an A/F meter). I will ONLY use my s-AFC when not on the bottle though. Make sure you guys run enough fuel and you will be just fine.
